Intermittent single knock when turning?
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOLORES BLOCKER
I hear a single knock in right rear area when making a left-hand turn and not every time.
Oct 17, 2022 at 6:59 AM
  • 110,248 POSTS
It could be the result of a few different things. The most common issue with these vehicles is the rear leaf spring shackle. I don't know where you are located, but these are known to rust and break. When that happens, the leaf spring will hit the bottom of the bed and make a noise.
Additionally, there are stabilizer links and a stabilizer bar that could have play. No matter what, make sure the wheels are tight. That seems to be becoming the new pandemic. People forget to properly tighten them.
I highlighted and circled the shackle. I circled the other things to check for play or damage. Make sure to also check the leaf springs to make sure none are cracked, and the shocks are tight.
see pic below.
Oct 17, 2022 at 12:09 PM
DOLORES BLOCKER
Thanks for your answer, it was a bad bushing in my anti-sway bar. Choked my budget for this month because also my thermostat housing was cracked! $1100 for repairs but I am safe now for numerous out of town medical appts
Thanks again!
Dolores
Oct 21, 2022 at 7:22 AM
  • 110,248 POSTS
You are very welcome. I'm glad the problems have been resolved. However, I can't believe they charged that much for the repairs. That seems really high.
Regardless, please feel free to come back anytime in the future. You are always welcome.
Take good care of yourself,
Oct 21, 2022 at 2:02 PM
