Simultaneous electrical problems
38,000 MILES • 2.2L • 4 CYL • TURBO • 2WD • AUTOMATIC
ERIC CHEESEMAN
1). Initially boot release switch failed to operate intermittently then permanently, fob continued to operate as normal. At the same time other faults appeared. Fob operation to lock/unlock continues to function but without light flash indication. 2). Passenger wing mirror failed to operate, adjust or dip, both wing mirror heaters failed. 3). Front passenger window fails to operate and passenger door lock only works manually.
Mar 13, 2018 at 1:33 AM
  • 31,937 POSTS
Have you checked the fob batteries? and with the door electrical problems, have a look at the loom through the door to the body, with doors constantly being opened and closed, you can get a fractured with in these looms, always a good place to start looking for these problems.
Mar 13, 2018 at 9:26 AM
