signals and four ways do not work
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN WEEKS2
Neither signals nor 4 way flasher work. Fuses check okay.
Jul 29, 2021 at 12:43 AM
SQM
  • 6,383 POSTS
Given that the fuses are good, you probably have a faulty flasher relay/fuse.
It controls the turn signal flash as well as hazard.
It is located on the left side of instrument panel under the dash.
I have attached the location diagram as well as replacement procedure.
Jul 29, 2021 at 1:27 AM
