Once in awhile the signal lights will not turn on
2000 FORD FOCUS
251,000 MILES • AUTOMATIC
MCCAWJ
When driving my signal lights work most of the time but every once in awhile they wont turn on. I have changed the indicator switch on the side of the steering wheel but it did not fix it.
Any ideas would help
Dec 5, 2016 at 9:12 AM
CARADIODOC
  • 34,384 POSTS
What you are describing is one of the typical ways the flasher can fail. These are no longer the extremely cheap and reliable thermal flashers that worked fine since the 1930's. They are now expensive electronic modules that are prone to failure. Start by replacing that.
Dec 5, 2016 at 2:33 PM
