driver side rear turn signal is hyper flashing very fast?
64,000 MILES • 6 CYL • TURBO • 4WD • AUTOMATIC
DAVID SHAW
My truck, driver side rear signal is hyper flashing very fast. I replaced the complete signal light with a new one since there was water inside. After replacing the new light system, it is still hyper flashing. I removed the right back taillight and connected it to the left side but it hyper flashed.
It works fine on the right side so I re-installed.
I have attempted to locate the turn signal relay to see if it is bad. But looking at the diagram there are no relay signal listed, but other relays are listed for what item they control. I turned the left rear signal on
again, and as it hyper flashed I took a long screwdriver and attempted to
hear the relay open and closed a long with placing my finger on all the relays one at a time and I could not feel or hear a relay working. I am checking the fuse box in the engine compartment. Everything I checked showed the relay for the rear signal lights is located in the engine compartment. I have a Duramax diesel engine. It has to be running for
the signal lights to be checked unless there is another way to perform this task. I checked my owner's manual and the relay is not listed. I may
be wrong about checking the Engine compartment fuse box is the correct one to check. There are two others inside of the cab.
Need help.
David
Jun 12, 2024 at 8:03 AM
  • 110,248 POSTS
Hi Dave,
A hyper flash is usually either due to a burnt-out bulb or if LEDs were installed to replace an incandescent bulb.
When you have the signal on, are all signals flashing fast on the affected side? Make sure nothing is burned out on the front. Also, by chance, have you installed LED bulbs to that side?
Jun 12, 2024 at 1:57 PM
