engine Shutting off
200,000 MILES • 3.2L • V8 • AUTOMATIC
KENNY POWERS
Well whenever I put my car in gear and drive if I go over 2000 rpm's it shuts off. But it will start right back up. It has a new fuel filter and fuel pump I also replaced my CMP sensor. I had the codes done but I misplaced the print out. I remember the guy at Auto Zone saying that I needed a fuel pump and my check electrical systems lights is on too. Thanks.
Jul 3, 2017 at 8:21 AM
  • 55,770 POSTS
The best way to tell which system is failing is to isolate the problem. When the engine stalls see if you have spark.
We should read the codes again to get the code which will help as well.
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Jul 4, 2017 at 3:57 AM
KENNY POWERS
Thanks guys I'll let you all as soon as I get the codes again
Jul 5, 2017 at 1:13 AM
  • 55,770 POSTS
Sounds good
Cheers, Ken
Jul 5, 2017 at 11:04 AM
