Shutting off while driving
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
KELLER132
Whenever I drive vehicle loses power then shut off. After 5 to 10 minutes it started again and drive again.
Aug 27, 2019 at 4:27 PM
Good morning,
Does the transmission shift okay?
Can you rev up the engine in neutral?
https://www.2carpros.com/articles/engine-has-low-power-output
I would start by checking the fuel pressure. Low pressure from a failing fuel pump will cause this issue.
Aug 27, 2019 at 7:21 PM
