Intermittent engine shutting Off
210,174 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MANDY BRIGHT
My car was shutting off often. It will do it randomly and less often than when I first got it. The car had been sitting for a while. Had bad gas but that is no longer an issue. It sometimes sputters and acts like it wants to stall out when I am driving it. I refuse to drive longer distances because of this problem. I really need to know what could be causing this problem. I have used a computer to check codes, the codes it threw were the mass air flow sensor and gas running lean. I fixed that problem. I am just wondering what else can be done to fix this problem without costing me a lot of money? I also replaced the speed shift sensor. Is there more to it?
Oct 20, 2020 at 2:36 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, you might have a weak or failing fuel pump that is not providing adequate fuel pressure causing this symptom. That is what I would check first. Here is a tutorial showing what is involved to test the fuel pressure:
If you don't have access to a fuel pressure tester most auto parts stores have a tool loaner program and can rent you one. The fuel pressure specification for your car is with Key On-Engine Off is 48-55 PSI. After performing this test get back to us with what you found and we'll go from there. Hope this helps and thanks again for using 2CarPros.
Danny-
Oct 20, 2020 at 3:16 PM
