1999 Buick Regal STALLING OUT AFTER ABOUT 8 MINUTES
WIRTAP01
  • 1999 BUICK REGAL
Engine Mechanical problem
1999 Buick Regal 6 cyl All Wheel Drive Automatic
FIND OUT PROBLEM AND SOLVE
Monday, June 1st, 2009 AT 10:47 AM
AKANYR
  • 52 POSTS
Hi, I have an 88 Regal with the same exact problem. My car idles steady for 1 minute then it revs up a little for a second then it go's down for a second for the entire 8 min til it stalls. The most common causes are:
1)dirty fuel injectors, pick up a bottle of Lucas brand 'Upper cylinder lubricant & Fuel Injector Cleaner' & double up on the measurement listed on the label. Then keep your foot on the gas pedal til the car stalls & keep do'n it. U may see some smoke out the tail pipe, it's good! That's the gunk burn'n off ur injector & clear'n out.
2)bad or dirty MAF sensor. Pick up a can of MAF sensor cleaner.
3) Dirty Throttle body, You can probably use the MAF sensor cleaner to clean the throttle body too.
A bottle of Lucas is about $5 & so is the MAF sensor cleaner.
Tuesday, September 29th, 2009 AT 7:32 AM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
