shutting down
98,000 MILES
HOWARD09
I have had problems about a month ago i bout a new battery got a cam shaft sensor and a crank sensor put on my car and the codes were pulled and I got every thing fixed that was wrong now I just don't know what to do (my car radio screen said the car energy was reduced then it shut of and it also shakes when im at red light then it will eventually will shut off)
May 10, 2013 at 10:15 PM
sounds like a vacuum leak somewhere. look around for cracked or broken lines.
what were the code numbers????
May 10, 2013 at 10:29 PM
HOWARD09
I DONT HAVE THE CODES ANYMORE BUT IT WAS THE CRANK SHAFT POSTION SENSONR,GAS CAP, CHANGE OIL AND THAT WAS ALL THE CODES SO I GOT ALL OF THAT FIXED NOW A MONTH LATER ITS MESSING UP AGAIN SO THIS WAS JUST YESTERDAY SO I HAVENT HAD THE CODES PULLED AGAIN
May 10, 2013 at 10:33 PM
ok, we need the codes. do not erase them as that does nothing.
did you have the fuel pressure checked??
May 11, 2013 at 12:00 AM
