Shutters in reverse?
220,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MARK ROB
When you go in reverse the whole truck shakes but when you go forwards. It runs fine. Don’t have a clue what that would be.??
Jun 10, 2025 at 11:53 AM
  • 55,710 POSTS
Yes, when the rear end starts to go out the wear in the gears can make it do this. When driving forward do you hear the rear end humming? If so this can be the case. I would remove the rear end cover to check the condition of the gears set. Here is a video to show you how:
https://www.youtube.com/watch?v=zarxKsspr3s&t=688s&pp=0gcJCckJAYcqIYzv
Also, I would check the transmission fluid level and condition, see if the fluid smells burnt and is discolored. This can be a sign the reverse clutches are burnt up. This guide can help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please go over these guides and get back to us.
Jun 11, 2025 at 1:54 AM
MARK ROB
Hello, we figured it out and had a loose caliper on the front end and it was dragging on the inside of the rim somehow a bolt fell out of it. Thanks for your response.
Jun 13, 2025 at 4:51 AM
  • 55,710 POSTS
Good find, that will do it. thanks for letting us know.
Jun 13, 2025 at 4:52 AM
