Shuttering when going up a hill or grade
254,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JINGLEWIP
The transmission shifts fine. When going up a hill or grade and putting the car under a load it starts shuttering and sounding like it is going over a rumble strip. Let off the gas and it quits and goes like it is supposed to except under its own power but lose speed.
Nov 2, 2018 at 4:26 AM
  • 110,251 POSTS
Have you checked fuel pump pressure? Also, have you checked to make sure the catalytic converter isn't plugged? Does the check engine light stay on or flash when this is happening?
Here are links that show how to check fuel pressure, a catalytic converter, and the third is a quick video on using a scanner. Check these things and let me know what you find.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://youtu.be/YV3TRZwer8k
Nov 2, 2018 at 12:00 PM
