Engine shutters when accelerating and getting poor gas mileage
226,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MATTIIE_B
Has a bad shutter when I go to take off and A/C only works at high speeds, and its using a lot more gas than usual.
Jun 10, 2020 at 8:13 AM
I suspect you have two issues. The shudder and fuel mileage sound like a misfire. The A/C only working on high speed is not related so we need to separate that issue out into a different post so that others that have that issue can find it. They will not find an A/C issue under this heading.
As for the shudder, does the engine idle smooth and only shudder when you are accelerating? Is the check engine light on? If so, we need to get the codes.
If there is no check engine light, is there a point at which this goes away? In other words can you reach a speed that it no longer does it or maybe an RPM that it goes away?
Jun 10, 2020 at 8:49 AM
MATTIIE_B
It only does it when accelerating. feels like the shudder is under passenger seat and around rear wheel area. when it warms up it has a light start blinking on the left side of dash panel.
Jun 10, 2020 at 12:58 PM
The light is interesting. Can you get a picture of this light? That I am sure will help figure this out if that is flashing every time this happens. Thanks
Jun 11, 2020 at 11:30 AM
MATTIIE_B
If you can see it. I do not know.
Jun 12, 2020 at 4:59 AM
I see the picture but the light was not part of the picture. Can you describe the light? What does it look like when it comes on? Is it just a light or a symbol?
Jun 12, 2020 at 12:31 PM
