First, does this happen if you are stopped with the transmission in neutral or park? If it does, the first thing I would check for is an engine vacuum leak.
Here is a link that explains how to find and repair one:
Also, if the check engine light is staying while the engine is running, I would have the computer scanned to see what diagnostic trouble codes are stored. Most parts stores will do it free of charge.
Keep in mind, there are a few different things that can cause this to happen. For example, a faulty idle speed control valve, fuel pressure issues, and so on. If you have the computer scanned, it will help point us in the right direction.
Jul 18, 2024 at 12:55 PM
