Shuts off while driving/rough idle
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
KRISTYK
Cranks up fine but sounds rough. Hesitation changing gears from start. Try's to stall when at a stop. Will shut off while driving after about 15 or more miles. Cranks back up but will only go quarter of a mile then shuts off again. Changed fuel filter. Ignition. Wheel bearing. Codes are different each time. 02 sensor camshaft sensor vacuum leak.
Mar 16, 2021 at 7:01 AM
As I was reading this, I was thinking it was a vacuum leak so the fact that you have a could that points in that direction, then that means we need to start here and make sure we find it and fix the leak then retest the rest of the operation.
However, I suspect if we find the leak then it will fix all the issues that you are seeing at this point.
Let me know if you have questions and we can go from there. Thanks
Mar 17, 2021 at 11:09 AM
KRISTYK
Hey, sorry I'm still checking all the leaks and things. I'm just learning all this but I will let you know when I'm finished. thank you it's a lot of help with that link.
Mar 23, 2021 at 2:28 AM
