Check both connections on the battery, disconnect the battery and strat of with a fst charge, then change it to a slow sharge. This will bring the battery up slower but the charge is deeper. After you have cleaned the battery teminals replace battery after charging. The vehicle should start as long as there is nothing else wrong with it. Take the car to somwhere like auto zone or advance auto parts and have them check the charging sytem. Some places have goten away from doing this so check around.
What you had described in your post sounded like the altinator was not charging or a bad ground to let the battery charge. Then tension on the belt could hav caused the altinator to fail, but I think the bearings would have started to make a noise first. I might be wrong but check the connections on the battery terminals especially the ground.
SPONSORED LINKS
Friday, June 5th, 2009 AT 2:19 PM
