Shuts off while driving
190,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
03CHEVYS10
Engine shuts down while driving in afternoon. no warnings, no check engine light. Pull over and restart truck and go. Last time it did this it took 3 tries turn over .
Dec 15, 2019 at 2:05 AM
Good afternoon,
This could be tough to track down. There are several possibilities. I doubt it is fuel related as it starts right back up.
https://www.2carpros.com/articles/engine-stalls
It could be an ignition switch which was really common.
Ignition Switch Replacement
Tools Required
- J42759 Ignition Switch Connector Release Tool
Removal Procedure
Caution: Refer to SIR Caution in Service Precautions.
1. Disable the SIR system.
2. Remove the upper and lower trim covers.
Important: The abrasion sleeve located on the steering column wire harness assembly must be reinstalled. Make note of what connector is coming out of the abrasion sleeve for installation purposes.
3. Remove the wire harness strap (2) from the steering column and the wire harness assembly (1).
4. Slide the 2 connectors (2) of the turn signal and multifunction switch assembly out of the bulkhead connector (1).
5. Rotate the key alarm connector (1) 90 degrees.
6. Pull the key alarm connector (1) out of the ignition lock cylinder case (2).
7. Remove the passkey connector from the ignition lock cylinder case (2).
8. Insert J42759 into the ignition lock cylinder case (1) and slide the ignition switch (2) out.
Dec 15, 2019 at 4:52 AM
