A complete stop the engine shuts off
WALESKA
  • 2003 SAAB 9-3
  • 2.0L
  • 4 CYL
  • MANUAL
  • 150,000 MILES
My car keeps shutting off only at a complete stop, but turns back on without a problem. What can be the problem?
Wednesday, November 29th, 2017 AT 11:58 AM
  • 31,937 POSTS
Will it hold an idle? Sounds as if the base idle is to low. Also, run a scan for any codes, not all codes will set a check light. Check for vacuum leaks and do a fuel pressure test as well. Start here.
Wednesday, November 29th, 2017 AT 1:17 PM
WALESKA
That is the thing it does not always shut off. It can shift off at a stop then I keep driving stop again and it is fine then stop again and the idle goes completely down and it shuts off. I have checked all the hoses and it all looks good. The engine light has been on the code it gave a while back had to do with an oxygen censor.
Wednesday, November 29th, 2017 AT 1:42 PM
  • 31,937 POSTS
Can you give me the code? O2 sensors can give bad reading due to vacuum leaks, up stream exhaust leaks, high or low fuel pressure, faulty injectors, and general tune problems. A live data read will show if the O2 sensor is just out of range or has failed completely. This would be worth checking as well.
Wednesday, November 29th, 2017 AT 9:13 PM
WALESKA
Code P0491.
Thursday, November 30th, 2017 AT 4:37 AM
  • 31,937 POSTS
Secondary air injection system code.
Potential causes for a P0491 may include: Faulty exhaust manifold check valve A fuse or relay for the secondary air injection pump may be faulty A faulty air pump Leaking vacuum hose A bad vacuum control switch A dislodged a vacuum line A leak in the hoses/piping between the secondary air injection pump and the Combi or secondary air injection A sensor for the secondary air pressure may be faulty The combi valve itself is faulty The secondary air injection port in the cylinder head may be plugged with carbon The secondary air injection ports in the cylinder head may by clogged
Friday, December 1st, 2017 AT 8:30 PM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
