Shut off while driving
2004 CHRYSLER PACIFICA
170,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BENTLEYT17
  • 11 POSTS
I was driving it and it just shut off. I have replaced the PCM,crankshaft sensor,checked all grounds. battery and alternator are good. fuel pump is kicking on and new spark plugs but still will not start.
May 20, 2020 at 2:24 AM
BMDOUBLE
  • 1,139 POSTS
Did you scan it for engine codes? If so what codes did you receive?
May 20, 2020 at 3:30 AM
BENTLEYT17
  • 11 POSTS
Po 562. It's a low voltage code but I can't figure it out.
May 20, 2020 at 3:57 AM
Good afternoon,
The engine needs 3 things to run. Spark, compression and fuel pressure
https://www.2carpros.com/articles/engine-stalls
The fuel pump may run but not produce enough pressure.
When you crank the engine, do you see the tachometer move up a little while cranking? That will tell me if the crank sensor is working.
Compression. It should be checked. One cylinder on each side.
The 562 is for low voltage and that could be the reason for shutting off. You need a minimum of 12.2 volts for any of the modules to work.
May 21, 2020 at 5:45 AM
BENTLEYT17
  • 11 POSTS
Yes, has brand new crankshaft sensor. it kinda seems like it's not getting spark.
May 21, 2020 at 10:01 AM
Does the tachometer show rpm while cranking?
May 21, 2020 at 10:35 AM
BENTLEYT17
  • 11 POSTS
I don't believe so no.
May 22, 2020 at 6:05 AM
BENTLEYT17
  • 11 POSTS
I'm sorry yes it does.
May 22, 2020 at 6:06 AM
I am going to attach a diagram for you to view for the crank sensor. You will need a voltmeter to do a test.
I need you to put the red lead in the pink/yellow wire and the black lead in the dark blue/dark green wire. Turn the key on and tell me the volt reading.
May 22, 2020 at 6:33 AM
BENTLEYT17
  • 11 POSTS
Okay, i will let you know ASAP.
May 23, 2020 at 11:54 AM
BENTLEYT17
  • 11 POSTS
It read at 5.00v.
May 24, 2020 at 1:11 AM
Okay, then move the red lead to the other wire and tell me the voltage.
May 24, 2020 at 1:22 AM
BENTLEYT17
  • 11 POSTS
Reading the same.
May 24, 2020 at 1:28 AM
Okay did you check the fuel pressure?
Also, if you spray some carburetor cleaner into the air filter, does it start and stall?
May 24, 2020 at 1:34 AM
BENTLEYT17
  • 11 POSTS
Yes, and no start at all.
May 24, 2020 at 1:38 AM
BENTLEYT17
  • 11 POSTS
But didn't check fuel pressure.
May 24, 2020 at 1:39 AM
Check the pressure to verify you have fuel pressure.
FUEL SYSTEM PRESSURE
Regulated Pressure .................... 58 psi
May 24, 2020 at 1:45 AM
BENTLEYT17
  • 11 POSTS
I have to get gauge tomorrow, but besides that any other thoughts?
May 24, 2020 at 11:57 AM
One step at a time.
Let me know about the fuel pressure.
May 24, 2020 at 10:59 PM
