Should I replace my master cylinder cap
59,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
WALLY AB
  • 97 POSTS
I have taken it off so many times. The brake fluid is clean. It is the typical Hyundai/Kia style where you just twist it on, and off. I wonder if taking it on and off many times will wear down the plastic mounting points. It sits a hair looser than it was at first, but it is still snug. The gasket is in good shape. Should I worry about it?
Jul 23, 2018 at 3:32 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You should only worry about it if it was to start leaking. Usually the master cylinder reservoir is translucent enough to just monitor the level by looking at the side. Even if it looks low do not continually top off the level that is also a way to gauge the brake pad level. Brakes are a closed system so whatever is added come brake job time it has to be taken back out. I would leave the cap alone and just check for leaks when looking at the level. Hope this helps and please feel free to ask any questions. Thanks for using 2CarPros.
Danny-
Jul 23, 2018 at 4:29 PM
WALLY AB
  • 97 POSTS
Thank you for your reply. Would taking the cap and reinstalling many times make the cap leak anyways?
Jul 24, 2018 at 12:59 AM
DANNY L
  • 5,648 POSTS
Hello again.
Not at all. Thank again for using 2CarPros.
Danny-
Jul 24, 2018 at 1:14 AM
WALLY AB
  • 97 POSTS
Okay, thank you for your reply.
Jul 24, 2018 at 1:15 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Danny-
Jul 24, 2018 at 1:28 AM
WALLY AB
  • 97 POSTS
Does accidentally moving the master cylinder reservoir on the car get air into it? I saw the front grommet move while pushing it upwards but no fluid. Took car out and brakes feel the same. Does the screw prevent this from happening?
Jul 24, 2018 at 8:08 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, the screw/bolt keeps it in place. As I stated before the only time to be concerned is when you see brake fluid leaking. Hope this helps.
Danny-
Jul 24, 2018 at 3:55 PM
