Should i change the transmission oil in Chevrolet Epica 2009 ?
160,000 MILES • 2.4L • 6 CYL • AUTOMATIC
AMRALASEEL
Should I change the transmission oil in Chevrolet Epica 2009 ?
When I use the Brakes i feel that the car is jumping or not stable some people toled me that the the transmission oil in Chevrolet Epica 2009 never changed .
Jan 8, 2014 at 4:29 PM
CARADIODOC
  • 34,403 POSTS
I can only guess that what you're feeling is a pulsation in the brake pedal. That is typically caused by warped brake rotors. They need to be machined or replaced. Your mechanic will do a brake system inspection to determine if anything else is needed.
Jan 8, 2014 at 7:13 PM
