shorts in blinkers
109,678 MILES • 2.3L • 4WD • AUTOMATIC
FUZZYFLY
My headlights go off when i use my blinkers and my brights do not stay on.
Jul 11, 2017 at 4:57 PM
STEVE W.
  • 15,420 POSTS
Most likely issue would be a bad combination switch. Item five in the picture. You remove the steering wheel, the upper and lower trim covers and then the switch. Route the cable on the replacement back down through the column and connect it.
Mark the steering wheels position on the shaft before you remove it and lock the steering so the wheels can move.
There are two different steering wheels you could have a three spoke and a two spoke, the three spoke has a screw and tabs you push up to disengage, the two spoke has a simple pry off center cover.
Jul 11, 2017 at 5:09 PM
FUZZYFLY
Thank you very much.
Jul 11, 2017 at 5:22 PM
  • 55,770 POSTS
Nice work Steve W.
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jul 12, 2017 at 4:25 AM
