My radiator with a built-in transmission oil cooler has failed internally causing transmission fluid to go into the cooling system and coolant to go in the transmission system. If I drive with this condition for the short/long term, can it result in premature failure of cooling system components like Water Pump, Thermostat, Hoses, Gaskets, Seals, etc., due to coolant contamination with oil? And what damages can it do to the transmission system with oil contamination with coolant?
Jul 23, 2021 at 5:06 AM
