Short knock noise from right front wheel area
115,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JAIME HUDSON
  • 7 POSTS
When starting car, and when shifting automatic selector between park to drive, or reverse, there is a momentary (short) knock type noise from right front wheel area. Was occasional at first, but it happens each time lately.
Jun 2, 2018 at 3:54 PM
Good morning.
The noise you are describing sounds like a worn or bad motor mount allowing the engine to shift back and forth.
Below I posted the procedure for you as well as a couple of pictures. I also added the parts and a picture for you as well.
Removal Procedure
imageZoom/Print
1. Remove the coolant recovery tank mounting bolt.
2. Remove the coolant recovery tank and position it aside.
3. Remove the cruise control module mounting nuts and position aside.
4. Remove mounting nut from both A/C line (1) and position lines out of the way.
5. Install the J 28467-360 and raise the engine off of the mount.
imageZoom/Print
6. Remove the nuts holding the mount to the body.
7. Remove the bolts holding the engine mount to the bracket.
8. Remove the engine mount assembly.
part
https://www.rockauto.com/en/catalog/chevrolet,2002,cavalier,2.2l+l4+ohv,1434771,engine,motor+mount,5552
Jun 2, 2018 at 10:48 PM
JAIME HUDSON
  • 7 POSTS
Thank you! Will have that part checked by local mechanic.
Jun 3, 2018 at 6:07 AM
Sounds good. Feel free to follow up if you have any other questions.
Jun 3, 2018 at 6:10 AM
JAIME HUDSON
  • 7 POSTS
Is car safe to drive for now, 'as is'? (Until worn/bad part is replaced)
Jun 3, 2018 at 6:21 AM
Yes, it has a safety lock on it to limit its movements.
Jun 3, 2018 at 6:22 AM
JAIME HUDSON
  • 7 POSTS
Also, forgot to mention (sorry) that the floor mounted automatic gear selector would sometimes get 'stuck' (not work/move), but not lately. Maybe is related issue?
Jun 3, 2018 at 6:26 AM
No, that has to do with the shifter itself.
I attached a picture of the shifter. Make sure you lubricate all the moving parts.
Jun 3, 2018 at 6:41 AM
JAIME HUDSON
  • 7 POSTS
Thank you so much for your help. God Bless!
Jun 4, 2018 at 11:38 AM
You are welcome. feel free to follow up with any other questions.
Jun 4, 2018 at 11:42 AM
JAIME HUDSON
  • 7 POSTS
Roy,
Is WD-40 spray okay to lube the automatic floor shift linkage parts?
Thank you!
Jun 5, 2018 at 8:52 AM
Yes. Good choice Yes.
Jun 5, 2018 at 9:19 AM
JAIME HUDSON
  • 7 POSTS
Thanks! For all your help. Keep on truckin', Friend! :-)
Jun 6, 2018 at 9:35 AM
You are welcome glad to help.
Jun 6, 2018 at 11:07 AM
