When I hit a bump sometime my ABS, overdrive button and brake light symbol turn on
18,700,000 MILES • 3.8L • V6 • AUTOMATIC
OUT2LUNCH
ABS warning light comes on my overdrive button blinks off and on the brake light symbol comes on. Sometimes it does not until I hit a bump. Someone told me to use connection gel where I plug in my main wiring harness.
Oct 15, 2018 at 3:14 PM
Good morning.
The ABS light and brake light work together. It indicates a fault in the ABS system. The code is stored in the ABS module. A parts store can read it for you for free. Once I know the code, I can help narrow the area of failure.
As far as the overdrive light. That indicates a fault in the transmission torque converter. I would start by changing the oil/filter in the transmission and see if the light continues. A code is also stored for this as well. When you have the other code read, they should also see the code for the transmission.
https://www.2carpros.com/articles/brake-system-warning-light-on
Oct 15, 2018 at 7:37 PM
