Suspension is getting splashy
2007 FORD MUSTANG
120,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
RYAN SWITZER
I drive on windy bumpy roads. What would make the ride better?
Jun 6, 2019 at 2:09 AM
Hi Ryan,
You have what is called a MacPherson Strut design in the front. You can find a ton of upgraded parts on the internet that will stiffen your suspension. However, the first thing I would do is check to see if your struts are leaking in the front. If they are, just replacing them would make a difference. Same thing for the rear. check to see if your shocks are leaking.
https://www.2carpros.com/articles/replace-shock-absorber
In addition you will want to check for other loose suspension components. Mostly likely the struts or weak springs are causing an issue as you described so we want to make sure they are okay.
If you are just looking to improve the handling, then your options are endless. For starters you can get stiffer struts and front and rear sway bars. This will make huge improvements with minimal cost. After this, if will get a little more involved. Again, I would just look on the internet and you may be able to find a kit that suits your needs.
Let me know if you have more questions. Thanks
Jun 6, 2019 at 6:30 AM
