Shimmy at highway speeds
36,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
SCOTTPR
Slight shimmy at highway speeds. Had wheels balanced and rotated as well as alignment.
Jun 3, 2021 at 10:16 PM
Is this something that you feel in the steering wheel or in the seat?
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Depending on which you have will determine if this is in the front or rear.
Also, when you had the tires balanced, was there any wear to them? You can check the tires now to see if they are worn with the chart attached below.
Also, were the tires road forced balanced or just balanced?
If we can eliminate the tires, then the next likely cause is hub or rotor runout. This will require a dial indicator. However, we can get there once we know this info. Thanks
Jun 4, 2021 at 1:00 AM
