Shifts into 4WD on its own
107,000 MILES • 3.5L • 5 CYL • 4WD • AUTOMATIC
V1800ES
My truck occasionally shift into 4WD on its own. The first time on a sharp left turn. I got these codes from my reader:
U1000 Class 2 Data Link Malfunction
U1026 Loss Of Communication With Automatic Transfer Case Controller
U1064 Lost Communication With Body Control Module (BCM)
Jul 25, 2019 at 5:51 AM
  • 55,616 POSTS
There is a transfer case control module under the drivers seat that may have got wet or has gone out. here is the location in the diagrams below but we should start by checking the fuses. here is a guide and the fuse locations below:
Jul 27, 2019 at 6:07 AM
V1800ES
Question: If I buy a new TCCM will it need to be programmed? What about a used from the same year?
Aug 13, 2019 at 2:28 AM
  • 55,616 POSTS
It must be plug and play because the instructions on how to replace it does not mention the reprogramming. Check out the diagrams (below). Please let us know what happens.
Aug 13, 2019 at 3:08 AM
