My truck is the 1500 model. About 500 miles ago I replaced the transmission and used all synthetic fluids. then the rear end went out so I went and got one from a junk yard. it was out of a 1996 because it was out of a 1996 the plug for the ABS speed sensor on the hogs head was not the same. so I put a new one in for a 2001 and now the ABS light is on the brake light is on. It moves fine in reverse but if i put it in drive it will not take off. However, if i pull it down into first it will take off with full power then i can shift into second and third. any suggestions on what it could be? oh yeah and the speedometer is about 15-20 mph off.
Mar 12, 2019 at 12:46 PM
