It will not go into gear it won't get out of park?
90,000 MILES • V6 • 4WD • AUTOMATIC
ALMANZAR0923
My car will start no problem. It will not go into gear it won't get out of park. I can shift through the gears freely. But it won't get out of park.
Apr 25, 2023 at 3:47 PM
  • 55,694 POSTS
It sounds like the shift lock is not working but we should check the fuses first.
Here is a guide to show you how and you should check the fuses with the system on:
I have seen the IPDM go out and cause this problem as well, if the fuses are okay let's run a
CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is how the shift lock works, also there is a shift lock bypass near the shifter have you tried using that? Here is the location as well #9. Check out the images (below). Please let us know what you find. We are interested to see what it is.
Apr 27, 2023 at 6:55 AM
