Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Freestar
Drivetrain
Transmission
Symptoms
Not Shifting
Shifting problem from first to second gear
2005 FORD FREESTAR
150,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
MEL.CLARK
MEMBER
1 POST
My van builds up rpm's in first. Gear some times it will not shift to second. For a second or two. What could it be?
Sep 30, 2018 at 7:36 AM
Experienced Mechanic
Good morning.
The throttle position sensor on the throttle body is what controls shifting of the transmission. When it fails, it usually sets a code.
Do you have any codes set in the system?
When was the last time the fluid and filter has been changed?
Image (Click to enlarge)
Sep 30, 2018 at 9:36 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
