Recently got my c1500 truck running again. Transmission was swapped out due to past transmission each gear started going out until all gears went out. Current transmission the shifter stick would get loose from the housing bolts (maybe stripped from unscrewing to put gear oil) ended up putting new screws but then the clutch slave cylinder went out, replaced that. Back to bolts for shifter housing loose again went to tighten them but after tightening them the overdrive gear or fifth gear whichever it may be called and reverse do not work.
Sep 1, 2018 at 11:30 AM
