thanks very much ....shifting cable is good....the problem is when i tranfere lever from D position to N position it stay on D unless i push it forcely ,,,the same thing happen from N to D
Aug 11, 2017 at 9:04 AM
✓Experienced Mechanic
The neutral safety switch is what controls that operation. I would check that out, here is a guide some diagrams (below) that will help you get the problem fixed.
