SHIFTING GEARS
1997 HONDA ACCORD
230,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
GLORIA NICHOLS
I installed a new clutch on my car, but the gears are still not shifting good. I then installed a master cylinder and it still did not help. Last, I installed a slave cylinder and still it is not shifting gears. It is very hard to get the gears to shift, and some of the gears will not shift at all. I don"t know what else to do.
Oct 19, 2016 at 11:43 AM
AL514
  • 5,656 POSTS
Have you had a shop take a look at it and at least diagnose the problem. I am assuming a shop did the clutch, master and slave cylinder?
Oct 19, 2016 at 7:21 PM
AL514
  • 5,656 POSTS
Also, how much clutch pedal travel do you have, ? does it go all the way to the floor, hard to push on etc?
Oct 19, 2016 at 7:23 PM
