Transmission jerks when shifting from second gear to third gear over 2,000 RPMs
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
KELLI LYNN PRESTRIDGE
Jerks when shifting from second to third over 2,000 RPMs but under 2,000 RPMs it shifts good.
Nov 16, 2021 at 2:19 PM
  • 110,248 POSTS
First, is the transmission fluid clean and full? If you haven't checked, follow the directions below and let me know the results. (See pics 1-4)
Transmissions depend on what is called line pressure and shift solenoids to function. What you described at first sounded like a pressure issue, but I need to know if this is the only shift it happens during.
As far as testing, what really should be done is this. First, scan the can-bus system. CAN stands for controller area network. Basically, all computers/modules are tied together via a few wires. With this type of scan, trouble codes can be retrieved regardless of the module storing them. Here is a quick video showing how it's done:
https://youtu.be/InIlnsjOVFA
The other way to test for a harsh upshift is by driving the vehicle with a live data scanner and watching shift commands from the PCM/TCM (power/transmission control module).
I realize these are things that may be difficult for you to do, so let me know what I can do to help. Also, here is a link you may find of interest:
Nov 17, 2021 at 12:20 PM
Did you get my eply?
Nov 19, 2021 at 2:12 PM
  • 110,248 POSTS
Hi, Kelli.
I didn't receive anything. Did you attach it to this thread?
Nov 19, 2021 at 2:22 PM
