Truck will not shift out and it is slipping
210,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
NESHA22!!
  • 7 POSTS
When i put it into a gear it stalls for a minute and then go into gear. Also, it starts out in a high gear once it is cranked.
Mar 20, 2019 at 8:38 AM
Good afternoon,
Is the check engine light on? If it is, do you know the codes?
Make sure the fluid level is correct. I would start by changing the transmission fluid. There may be debris in the valve body causing this issue.
Mar 20, 2019 at 8:58 AM
NESHA22!!
  • 7 POSTS
Yes, the check engine light is on. But i do not know the codes . And i cannot get to an auto shop to run it for codes. Also, the fluid is full and i replaced a torque converter, transmission control solenoid, and speed sensor.
Mar 20, 2019 at 9:18 AM
Got it.
I need the codes to help narrow the area of failure.
You replaced the torque converter already?
Mar 20, 2019 at 9:28 AM
NESHA22!!
  • 7 POSTS
Yes, the torque converter, speed sensor solenoid , transmission control solenoid , and The position speed sensor has all been replaced . When i was able to drive it to the part store , i believe the code was 1715 however since all those parts have been changed out. I do not know what codes are popping up now.
Mar 20, 2019 at 9:38 AM
Okay, question.
Why did you not replace the clutches and steels inside the transmission when you had it out of the car?
Mar 20, 2019 at 9:45 AM
NESHA22!!
  • 7 POSTS
No one mentioned either. I have no clue about vehicles.
Mar 20, 2019 at 9:56 AM
Okay, you stated two times you replaced the torque converter. That is internal in the transmission.
I assume you mean the solenoid.
Did you change the oil/filter in the transmission?
Mar 20, 2019 at 9:59 AM
NESHA22!!
  • 7 POSTS
Yes, it was changed.
Mar 20, 2019 at 10:14 AM
Okay, we are back to the codes. You may need to have someone bring a code reader to you to pull the codes.
Mar 20, 2019 at 10:17 AM
NESHA22!!
  • 7 POSTS
I have one it keeps saying error.
Mar 20, 2019 at 10:22 AM
I wish I could help more but I have no information to work with except you replaced parts and I do not know why.
I think you should have it towed somewhere and have someone diagnose it for you.
Mar 20, 2019 at 10:27 AM
NESHA22!!
  • 7 POSTS
Thanks for your advice. i thought maybe something was wrong with the computer because i have a code reader and it keeps saying error, but when i put it on my other vehicle it works.
Mar 20, 2019 at 10:51 AM
I understand. It is hard from here to try to help without seeing it, touching it and physically checking it myself.
Mar 20, 2019 at 10:54 AM
