Shifting
178,671 MILES • 3.0L • V8 • 4WD • AUTOMATIC
PRIEST CARROLL
Once put in gear it does not shift to next gear. I have changed the transmission and transfer case three times same reaction. need your advise!
Oct 15, 2017 at 8:35 AM
STEVE W.
  • 15,413 POSTS
The power train control module operates both the engine and transmission. I would check to see if the wiring to the transmission is okay. Check all fuses. If they all look good I would suspect the PCM is bad.
Oct 16, 2017 at 3:08 PM
