Vehicle has been worked on for about two years now. I got it without knowing all that was wrong with it. It drove, I didn't see anything wrong under the hood, but apparently it was junk when I got it. That being said, it's drivable now, but was told there are still a couple of codes. One indicates the throttle sensor as included with the vacuum code. I can tell sometimes, it doesn't want to shift. I know it's not the transmission, and the engine is great. Could it just be a vacuum issue and not the throttle? The reason I'm wondering is because sometimes, the acceleration gets to above 4RPMs, and then shifts. Or, I have to let off the gas in order for it to shift. It couldn't also be the timing belt could it? I'm thinking it could also be a spark plug issue, but no codes come up for that. The vacuum code encompasses a myriad of issues that could be causing this delay in shifting, I'm asking if I should replace the throttle sensor to get started on fixing the issue. Thanks so much for all your help!
Nov 30, 2021 at 10:58 AM
