When driving 65 MPH or more transmission will not shift into fourth gear?
186,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KEVIN LOVELL
when i take it on the highway doing 60 or more miles per hour it won't shift into fourth gear at 60 MPH I'm running 3,500 to 4,000 RPMs. It's the re4f04b transaxle i can replace the solenoid myself if i knew which one to replace.
Sep 1, 2022 at 9:38 AM
  • 55,658 POSTS
Sure, but have you run the codes to see what comes up? You can get a code scanner from Amazon for about $20.00.
Here is a guide/video to show you how:
Here is a scanner link:
https://amzn.to/3Qi1SS6
It could be a turbine revolution speed sensor that has gone out, here are the locations for both and how to replace them in case you need it in the images below. Also, it looks like the shift solenoids are replaced as a unit. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Sep 2, 2022 at 1:07 AM
