When I go to take off in first gear the car barely moves?
146,000 MILES • V6 • 2WD • AUTOMATIC
RYANZ
The RPM gets a little high but not bad, then it hits a certain spot and goes back to normal. I sometimes experience this when the car downshifts. If I take off real fast, no problem.
Sep 20, 2022 at 3:11 AM
  • 55,694 POSTS
I would check the transmission fluid first here is a generic guide to help you with the steps and instructions in the images below to help you check the fluid on your car.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Fluid Types
AUTOMATIC TRANSMISSION FLUID
Fluid type: .................... ATF D-II or DEXRON III (DEXRON II (r)
DIFFERENTIAL FLUID
Capacities
Capacity:
Dry Fill: 5.6 liters (5.9 US qts, 4.9 Imp. qts)
Drain and Refill .................... 2.5 liters (2.6 US qts, 2.2 Imp. qts)
DIFFERENTIAL FLUID
Capacity: .................... 1.6 liters (1.7 US qts, 1.4 Imp. qts)
If the fluid smells burnt, you should change the fluid out
Sep 22, 2022 at 4:23 AM
