Shifter will not shift out of park without override
1990 LEXUS LS 400
300,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
MCMICAH
The shifter doesn't shift out of park without the override button which i wouldn't have a problem with except the override has become finicky and difficult to get it out of park even with the override. I'm told it's a relay in the shifter not letting it shift out of park and I'm trying to find out where that is.
May 8, 2019 at 6:24 PM
  • 110,240 POSTS
Welcome to 2CarPros.
The shift interlock control module is in the center console. See the attached pictures.
Picture 3 is a wiring schematic of the system. I'm adding it in case it's needed.
Here are a few links you may find helpful when working on it:
___________________________
Here are the directions for removal of the console. The remaining pictures correlate with the directions,
PROCEDURES
picture 3
1. REMOVE CONSOLE BOX
HINT: Tape a screwdriver tip before use.
(a)Using the screwdriver, pry out the cluster finish panel, and after disconnecting the connector, remove the Panel.
picture 4
(b)Using the screwdriver, pry out the lower console cover.
(c)Using the screwdriver, pry out the cover.
(d)Remove the 3 screws and lower console box.
(e)Remove the 4 screws and cup holder.
picture 5
(f)Remove the 4 screws and the console box.
Installation is in the reverse order of removal.
___________________________________
Let me know if this is what you needed or if it helped.
May 9, 2019 at 11:56 AM
