shifter not engaging gears at the transmission
0.5L • 4 CYL • FWD • MANUAL
MATTYB07
Must clutch to start engine. once running clutch is depressed. shifter will move into gear but will not engage. shifter will move thru and stay in all gears will clutch is not being applied.
Jun 19, 2014 at 8:17 AM
SATURNTECH9
  • 30,868 POSTS
If all the linkage is moving like it should sounds like you have a worn out clutch.
Jun 19, 2014 at 12:44 PM
