Shifter will not shift into park?
133,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MYGRTPYRREX
  • 5 POSTS
Unable to put in park.
Aug 15, 2023 at 2:47 AM
  • 110,248 POSTS
The truck has a shift cable that is adjustable. I'm not sure if you have already checked it, but you may want to see if it is an adjustment issue.
If you look below, I attached the directions for adjusting the cable. Take a look through them and let me know if you are comfortable performing the procedure or if you have already done it.
Aug 16, 2023 at 2:55 PM
