Transmission will not shift into park, the key is stuck in Acc position?
274,000 MILES • 0.6L • V6 • 2WD • AUTOMATIC
WIILD
Can't get car in park key is stuck in acc position.
May 12, 2024 at 4:35 AM
  • 110,248 POSTS
This may require a new tumbler. Before jumping to that conclusion, take a look through this link and let me know if it helps.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Also, let me know if you noticed anything prior to this happening that may indicate a possible other issue.
May 12, 2024 at 11:45 AM
  • 55,616 POSTS
Here is how the tumbler is changed out. Check out the images (below). Let us know how it goes.
May 12, 2024 at 12:15 PM
