Shift trouble
360,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
VICKI DUBEA
It will not shift from low to high and ignition key will not release.
Jan 31, 2017 at 8:06 AM
  • 55,710 POSTS
Hi VICKI,
This sounds like the ignition switch has failed and needs replacement, that had big problems which the switches in those cars.
Also check the transmission fluid level, also disconnect the battery for 10 minutes and then reconnect and retry. Check the battery condition as well here is a guide to test it.
Please let us know what happens so it will help others
Best, Ken
Feb 5, 2017 at 5:54 PM
