Which solenoid controls the transmission drive gear?
115,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
FERAVELLA
When I shift to drive it jerks loud and scary. shift to reverse is okay. Which solenoid controls the Drive? My car has 6 shift solenoids, or so it appears, but I need to know which solenoid controls the drive, reverse is okay.
Dec 4, 2020 at 6:14 AM
Good morning,
I found and posted below the possible issue with shifting shock, as they call it, for your transmission. It is not the shift solenoid, it is a internal clutch issue with the transmission.
If it were a shift solenoid, it would code and set the check engine light.
Most likely you will need to have the transmission removed and inspected for the underdrive clutch pack.
Dec 4, 2020 at 6:45 PM
