Shift stuck
120,000 MILES • 2WD • AUTOMATIC
ROADHAMMER05
Gear shift stuck in gear will not move and cannot depress brake pedal. Because it is stuck in gear will not start.
Aug 10, 2017 at 11:12 AM
  • 55,797 POSTS
Lets start by removing the shifter cable from the transmission and try moving the shifter. This will tell us if it is a cable or transmission problem.
You will need to jack the car up first.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please let us know what you find.
Cheers, Ken
Aug 14, 2017 at 2:43 AM
