Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Trailblazer
Drivetrain
Transmission
Gear Selector
Stuck
Shift stuck
2005 CHEVROLET TRAILBLAZER
120,000 MILES • 2WD • AUTOMATIC
ROADHAMMER05
MEMBER
1 POST
Gear shift stuck in gear will not move and cannot depress brake pedal. Because it is stuck in gear will not start.
Aug 10, 2017 at 11:12 AM
Experienced Mechanic
Lets start by removing the shifter cable from the transmission and try moving the shifter. This will tell us if it is a cable or transmission problem.
You will need to jack the car up first.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please let us know what you find.
Cheers, Ken
Aug 14, 2017 at 2:43 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
