Shift solenoids location
125,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JLOGAN3
Automatic transmission will not go into drive or reverse nor second or third gear just revs up rpm's.
Oct 31, 2017 at 6:42 AM
SATURNTECH9
  • 30,869 POSTS
That does not sound like a shift solenoid issue to the shift solenoids are under the transmission side cover that faces the drivers wheel.The left drive axle goes right through the side cover.
Nov 1, 2017 at 6:41 AM
