Transmission shift solenoids
JOSE ARAIZA
  • 2006 CADILLAC CTS
  • 3.6L
  • V6
  • RWD
  • 100,000 MILES
When I drive always when accelerating in between second and third gear my car jerks hard. Next weekend I when to a place to check my transmission and they said it had metal shavings and need it to rebuild the transmission but ""I think it is just the shifter solenoid that is getting clogged up or something" what should I do? Where is the shifter solenoid located? Should I replaced my self?
Saturday, September 2nd, 2017 AT 6:09 PM
STEVE W.
  • 13,648 POSTS
Metal inside the transmission is not a good thing. Shift solenoids don't get clogged unless there is some debris (like metal shavings) floating in the fluid.
The shift solenoids are all inside the transmission. BUT from your description try this test first, Shift into low gear manually. Now shift up one gear at a time. Does the trans still jerk hard when going into 3rd gear? If it does it likely has internal damage and not an electrical issue.
Tuesday, September 5th, 2017 AT 5:31 AM
KELI JACKSON
  • 2004 CADILLAC CTS
  • 3.6L
  • V6
  • 167,000 MILES
I am not sure which solenoid in my transmission that needs to be replaced. When starting to drive and shift into drive it takes about 45 seconds before it engages into drive gear. I also have no fifth gear, cannot take it over 55 mph. Any ideas?
Wednesday, March 31st, 2021 AT 9:42 AM (Merged)
  • 52,797 POSTS
Is the check engine light on? If it is a solenoid, it will code.
When was the last time you change the fluid and filter?
I attached the procedure for the pressure regulating solenoid. This could be your issue. The procedure with pictures are below.
KANGIE07
  • 2004 CADILLAC CTS
  • 3.6L
  • 6 CYL
  • 242,000 MILES
Can you please tell me how to replace a solenoid?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,628 POSTS
You will need to drop the pan and the solenoids are in the valve body. You will need to raise the car safely here is a guide for that.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
This help help pull the pan and service the transmission
Here are some diagrams below showing you how to do the job.
Cheers, Ken
ALLISON509
  • 2003 CADILLAC CTS
  • 3.2L
  • V6
  • 130,000 MILES
I have these codes on my car:
DTC P0762 4-5 Shift Solenoid (SS) Valve Performance - No Fifth Gear
DTC P0700 Transmission Control Module (TCM) Requested MIL Illumination
DTC C1244 Powertrain Indicated Engine Drag Control Malfunction
DTC P0171 or P0174 Fuel Trim System Lean
I need to know if I can do the solenoid myself. Someone else is telling me I have to drop the transmission and send it out to California to get worked on and then have it shipped back out here.
I also have no idea what Powertrain Indicated Engine Drag Control Malfunction means. I have looked online and am not sure what is causing this or what it means.
Any help would be very much appreciated. Thank you.
Wednesday, March 31st, 2021 AT 9:43 AM (Merged)
KEN L
  • 48,628 POSTS
Trouble codes are given in the order of importance so if you fix the solenoid the rest will probably go away. You can do the work yourself by removing the transmission pan this guide should help.
Here are diagrams to show you how to replace the 4-5 shift solenoid - below
Cheers, Ken
